HI. from the SONY ACID MUSIC STUDIOS 9.0 plug-in manager i loaded the wrong .dll files from a program that has nothing to do with music into my Sony ACID Music Studio 9, and now it cannot startup even if i uninstall then reinstall it, or even if i restore my WINDOWS 7 to a previous restore point. what should i do?
WHEN I CLICK THE PORGRAM ICON TO STARTUP, AS THE PROGRAM INITIALIZES AND AS MANY FILES ARE LOADING, THREE ERRORS ARE SHOWN ONE AFTER THE OTHER;
ERROR 1.
Error at loading ippJP library
No DLLs found in the Waterfall Procedure
ERROR 2
Load IPLib
No IPLib was found in the Waterfall Procedure
ERROR 3
Loading PreviewImageCreator.dll
IN ERROR 3 IT HANGS AND NEVER FINISHES LOADING.
as its loading the dll flies, it reports two problems saying Problem with the Waterfall Procedure, then when it gets to another dll file i shouldn't have installed it hangs.
what i actually did was to use the Plug-in Manager to add a complete Sony Folder because i also use a SONY VAIO, so the folder contains many software that are meant for visuals [just for the laptop].........
FROM: Local Disc (C:)\PRogram Files (x86)\Sony\VAIO\ Creations\Click to Disc
ACID Music Studio 9.0
ISB Library
Media Gallery
PlyaMemories Home
PLAYSTATION Home
PLAYSTATION Network Downloader
PLayStation Store
PMB VAIO Edition Settings
Prepare Your VAIO
Remote Keyboard
Remote Play with PlayStation 3
SetupapiLog Checker
Shared Plug-Ins
TrackID with BRAVIA
VAIO Camera Gesture Utility
VAIO Content Monitoring sETTINGS
VAIO Control cENTER
VAIO Creations
VAIO Data Restore Tool
VAIO Easy Connect
VAIO First Logon Setup Tool
VAIO Improvement
VAIO Manual
VAIO Original Function Settings
VAIO Recovery
VAIO Startup Setting Tool
VAIO System Diagnostic
VAIO Transfer Support
