please ADVICE: XP on recovery discs
danstijl
Visitor
Hi People, I want to buy a new desktop and was wondering if I can use the XP on the recovery discs of my sony desktop or laptop, for my new computer. Is this possible? Or do I have to buy XP new..... :slight_frown:
I hope you give me some advice, otherwise costs me so much for xp....
Thanks guys, appreciated
1 REPLY 1
profile.country.GB.title
Blencogo
Expert
The Recovery Discs will only install on a Vaio computer.
The installation will check to computer's BIOS for a code which will identify each Vaio by its make and model type.
:slight_frown:
