I have a 2.4 Ghz Sony VAIO PCG-VRZ515G
It has really bad performace problems, I am a musician and so run some intensive software, and need the laptop for live performance.
When I start to run my music software, Cubase SX or Ableton Live, the computer slows down to a crawl - if I check, in Control Panel -> System the actual CPU speed, it starts at a normal 2.39 Ghz, and after running the software for a minute its slowed down to 882 Mhz. If I quit the software and go back its then 2.39 Ghz again.
I have been advised to clean out the air vents with compressed air, which I did, but this has only stopped it overheating, not the performance problems.
If I could afford it i'd sell it and get a Centrino, but for now I need to try and solve this with what i;ve got. A 2.4 Ghz processor should be flying along, but it seems slower than my old 700 Mhz Athlon machine.
Any help here much appreciated,
thanks,
adam.
should read: PCG-GRZ515G
Adam,
Make sure you are using the "performance" setting in PowerPannel.
A lot of music apps these days use CPU cycles like crazy.
Yeah tried that too...
I think its just heat causing the processor to under-clock.
Maybe I need to get a mini fridge for it!
Damn, dunno how its gonna cope in a hot sweaty club...
Yeah I know....
Maybe you should get a laptop cooler that goes on the underneath?
yes a laptop cooler is a necesity..especially if used within a hot environment like a club.. it should drop your systems temperature by 5 degrees or so
sorry im in a rush but if u look thru the forums, you'll find a thread called measuring the temp of the k series, within their you'll find a link to a program which measures the temp of your laptop..
when running your music programs and when u encounter a slowdown, make sure you have this program running so u can log the temperature..
if your getting temps of 65 degrees and above, that sounds dodgy and 75 and above and u better start investing in cooling solutions or speak to sony..the cooler the better, as u know.
however, if your laptop stabalises at a temp in the 50s, it is not a temperature issue hence another system fault which sounds difficult to identify..though quite worrying
sorry i couldnt have been of more help
nick
Running MobileMeter is a good idea so we can see if it's tempreture problems.
How much memory (RAM) have you got installed?
The default install for that model seems to be 256MB - that is borderline for effective performance on Windows XP. If there isn't enough real memory XP will start to use virtual memory on disk causing performance degradation and a bit of heat.
I have 512Mb installed - minimum for music apps.
Will try MobileMeter and did not even know about laptop coolers!!
Thanks guys.
Adam.
With big apps and VST plugins you really should consider getting the big 1GB of RAM
