Hi all. Newbie here.
I have a PCV - V1 and find that the factory max volume is not loud enough (I've got young kids and sometimes you are left with no choice but to take it up a notch!). Is there anything I can do to change the settings?
Apologies to all you Vaio masters if you have already done this one - I did check a month or so worth of previous threads (honest).
LOL @ the ASBO bit
Yes, those speakers in the V1 are a bit cack to say the least
Do you have sonicstage mastering studio audio filters. it has an inflator feature which can increas the max volume. You could also look for similar inflator plug ins if you do not have SSMS.
