Having a problem. I am trying to use my new PC to capture a video so i can edit it in Pinnacle Studio 8. Every time I click capture. I get a capture error. Any ideas?
How are you capturing and what from? For example, are you using a camcorder with iLink or a capture card etc?
If you let me know I may be able to help
Did you get all the latest updates for Pinacle 8?
I have down loaded the lastest patch from pinnacle 8.8.17
I'm using the card supplied with the vaio.
Sony TV Tuner (4830) WDM Video Capture
i have the same problem i ended getting movie box dv you can input anything and out put to anything only my mini dv i have no problem with it was just analoge i was have trouble with
