Hi all! Ill get straight to the point.
When I switch on my PC after say a good few hours the PSU Fan goes from a little noisy to very noisy. Basically it sounds like it is about to fly off from its perch at a very high speed.
From what it sounds like the fan seems to be struggling in the first instance. However when I switch off and then turn it back on again straight away the fan behaves and sounds fine.
Now I have a very limited amount of warranty left on my desktop so who should I be contacting, DABS (where i bought it from) or Sony??
Pls help, would like to avoid buying another PSU especially if I am still under warranty.
Thnx in advance:smileyhappy:
You need to speak to Sony about it.
