I formated my PCV-RS222 desktop, and installed Windows XP Professional on it, but I don't have driver for "Multimedia Audio Controller", "PCI Modem", SM Bus Controller",USB Controller", "Video Controller (VGA Compatiable". I cannot get these drivers from the Receovery CD.
Does anyone know where can I get these drivers? or the name/model of these devices?
many thanks for help!
Weng
The only thing you can do is use the Recovery disk, install the old operating system and make a copy of the drivers folder. Then instal professional again. It is indeed rediculous, but Sony refuses to give us the drivers. It would be very easy for them to support us by putting the drivers in a .zip file. Great help, small effort. I have the same with a RS322. Maybe some has the directory? (UK version)
Martenl
