Hey everyone
I have just got one of the above laptops off Ebay. All the recovery / Util CD's are Japanese and I can't find any links on Vaio Support to download the drivers / Apps or Manuals.
Can anyone point me to where I might ne able to get this info?
Sony Vaio PCG-SRX55TH
Thanks in advance
Barry
You should be able to access drivers etc here
I think you will have a problem if you want to change the OS to English, or anything else for that matter
Thanks for the response Dave but unfortunatly this site does not list that notebook at all. Nearest thing is the srx41. Not sure if that has the same internals but I guess I can try it.
Thanks
Barry
Sounds like an American machine, therefore Sony Europe won't help
It is not a USA model its an "Asia Pacific" model.
I have this link for you but unfortunately there are only updates not the original drivers:
http://www.css.ap.sony.com/VAIO/download/downloadList.asp?cat=VAIO%20Notebook&Model=PCG-SRX55TH
Also found this which gives the specs:
http://www.sonystyle.com.hk/vaio/pdf/pcg_srx55th.pdf
I can only suggest you spend some time looking for similarly equipped Vaio's here and on the USA site and where applicable download and try the relevant original drivers
Here is the USA link:
http://www.ita.sel.sony.com/support/
Good luck
Thanks Mandy....
