Is anyone else having problems with the K115 series freezing. It happens normally after 15-20 mins of use and can occur during any activity (normally low or idle) the mouse freezes up and nothing responds (not even ctl+alt+del) You have to hard power off. It happens a lot when using Internet Explorer.
I tried restoring using the system restore disk and that seemed to solve it, but 2 days later it seems to be happening again.
I have registered the warranty but when I try to log into e-support it states it doesnt recognise my email address.
Most frustrating....please advise
Mike
As far as esupport is concerned, I understand that a 'phone call is usually more effective
I've no idea why your machine should still be having the same (strange) problem after a full recovery - unless you have a virus - is your AV software up to date?
Do you have a wireless LAN running?
Please try to run the Windows Update.
Tools>Windows Update
It seems there is a sensitivity with Flash or Java on that model.
Also try to disable all unnesecary apps in the background.
I find a lot of VAIOs have a problem with Flash and Java
Yes I do have the wireless LAN running
I'm not sure if the antivirus is up to date. It is the same as what is installed by default. I've barely used the system since restore though so I would be surprised if a virus is causing the problem. Is a system freeze a symptom of virus infection?
Exactly the same model K115Z - and I had the same problems from beginning. I did not care much for them, as I did not plan to keep XP home and the very much reduced software package. So, I did a clean new install with XP Pro SP1 - working fine. I installed several application - no problem. I managed to get all drivers updated and running fine. Then I used Windows Update ... and there the problem started again after trying to install Media Player 9.
Since that it was not fixable. ... until I said good bye to MS and installed Linux Mandrake 10.0.
After 30 Minutes EVERYTHING was working perfect.
I am happy now.:smileygrin:
