First thing i did when i got my new Vaio was put XP Pro on. Now i have come to re-install the DVD decoder from the Vaio recovery disk and it wont work. I get the the menu, click the button to install a single piece of software and i just get 'Such and such file could not be found' and the program terminates. Cant find the software manually on the CD as it all seems to be compressed. Is the decoder available to download somewhere online from sony? I dont fancy paying for it. I've tried installing WinDVD which i use on my desktop, but this crashes whenever i use it on the Vaio. Please help, just bought a new movie i cant watch
if u just want 2 play a dvd just us window media player.
I Had a similar problem in end i just used recovery disk then installed xp pro as an upgrade.
install XP pro as an upgrad couldn´t be the resolution to get all problems fixed - the whole driver support for pcg-k115m is poor till now
or did anyone know where to find them ?:smileyconfused:
Reinstall WinDVD.
great, they are up there now @vaio-link.com - i got them :smileygrin: all drivers are mine.. muahhha
