ANYONE HAVING PCG-GRX51/BP :smileyconfused:: :!: I NEED IMMEDIATE HELP TO SOLVE SOME OF MY DRIVERS PROBLEMS, LIKE: DISPLAY, FN KEYS, AND AV OUT [*-:smileyhappy:] I LOST MY CDs CAME ALONG WITH THIS LAPTOP AND USING XP PRO.
PLS HELP ME AS SOON AS POSSIBLE. THANK YOU.
try vaio-link for drivers and US sony support site too
THANKS FOR YOUR QUICK REPLY. WOULD YOU PLEASE SEND ME THE LINK OF THE SITE YOU ARE REFERING ME TO RESOVE MY PROBLEM OF DRIVERS?
MANY THANKS...
Please don't use caps lock, it looks like you're shouting and it's not easy for us to read.
Sorry Kee-Lo
Any update regarding my PCG-GRX51/BP Drivers/software?? Thanks a bunch!
Younus
www.vaio-link.com
http://www.ita.sel.sony.com/support/
note the model number differ in every country so check for same spec and so on
Hehe thanks, I was looking for the US one, but I couldn't find it.
With the help of Mr Shrek, I found some drivers which are close matches to my laptop. I put them on downloading and will give a try one by one in order to resolve the problems.
QUESTION: Is it advisable to update drivers for BIOS??
Thanks for everyone support.
Younus
BIOSes don't need drivers.
dont update the BIOS unless you are sure, just try installing what you need most first.
