Hi. I have a Sony Vaio laptop. The screen doesnt come on but the lights on the front do. Any ideas. Ive been told its possibly motherboard, how much are they to replace. Can I also check if it is in warranty? I did not buy from a dealer
Try plugging in a monitor? Do you see a picture on there?
If you do then it's more than likely your inverter which has gone kaput
thanks for the reply. Tried that but no good, but wasnt sure if it was coming on or not. Tried pressing the f8 key (I think it was that f number) to switch between laptop and plugged in monitor but no good
thats what I meant, yes tried that
Sounds like a graphics card failure
Did you try Fn + F7?
No, I think I have pressed just about every other key
