My eyes really likes the comfortable ink-screen of the Sony PRS-T2. Does it exist some ink-screen that I can connect to an ordinary PC?
Hi there
Do you mean you would like an e-ink style monitor / screen? Or that you would like to be able to connect the PRS-T2 and view your pc and desktop etc through that?
There are ways that you can connect readers like a KindleDX as a PC display, but it involves jailbeaking the device which automatically voids your warranty and you need about 5 different bits of software to do it. I don't know about the PRS-T2 but would suspect a similar process would be needed. So far I haven't found any details relating to this model. Hopefully someone else may be able to help
