Hi.
Where can I find the original Vaio Wallpapers in size 1920x1200 for my vgn-a117s? I've just installed xp pro instead of the (recovery) home edition and therefore I lost these files. On club-vaio.com the wallpapers are only available up to a resolution of 1600x1200.
thanks,
chris (ger)
Are they not on your recovery DVD?
Hi
I Found a thread on the fun page that might be what you are looking for.
http://www.club-vaio.sony-europe.com/clubvaio/mvnforum/viewthread?thread=2519
If that doesn't get you there its titled (SHARE) All my vaio stufs.. and is on the first or second page.:smileyhappy:
Damn, I thought they just had the wallpapers on the disk.
Hello,
I have also installed Windows XP with SP1a english on my vaio VGN-A117S laptop, but I have problems with the bluetooth device. When I use the bluetooth/wireless button on the front of the laptop, windows says found new hardware UGX and i simply can't find the drivers for this device. I know it is the bluetooth.
Did you have a simular problem and if so how did you solve it?
Thanks for any response:smileyhappy:
Check c:\drivers\
BTW what has this got to do with wallpapers?
Hi Kee-Lo
Not so much, but ckmdb has upgraded to win XP Pro, so I wanted to know if he had the same problems before I posted a new thread.
Thats more than likely where the problem lies!
As I've already wrote I installed Windows XP Pro instead of the provided Home Edition
VAIO Sicherheitskopie für Sony-Serie VGN-A100error.
