Hi there,
I recently acquired a Clie NZ90 (its sweeeet) however im having problems playing movies recorded with it on my PC. Is there any specific software required to play them as they dont seem to be in a format im familiar with.
Thanks in advance,
J. Kapantais
Try playing the movie with Quicktime. It is QT MPEG4.
I also recommend that you have a look at www.cliesource.com - you will find lots of hints, advice & tips for your NZ there. They have a very active Clie forum.
Thanks
Quicktime 6 to be precise
Just rename .mqv in .mov, and enjoy your movies !
mpeg 4 to be really precise. Quicktime 6 is just one of the many programs which will play the format.
