Hello,
I´m a newby and maybe my question is
a little big boring...
Where can I get the latest driver for the
"Nvidia geforce fx go 5600" card?
Thanks for any advice!
Chris
try the sony site:
www.vaio-link.com
once there... look for drivers and patches.... then continue as told...
remember one thing though... the fan doesn't get any quieter....
we are all waiting for sony to bring out a bios update that fixes this (not really a problem says sony)
joe
Hi there
I downloaded the latest drivers from nvidia and installed them. This did not install the driver because there is no "go" driver in the package. But it created a new folder on the "c" dirve "NVIDIA Display Driver".
I then updated the drivers manually, overriding all warnings. I took the normal 5600 dirver which works fine. I also checked the graphics prosessor and ram speed. They are the same in the original go driver and the normal 5600 driver so there should be no heat problem.
The new driver is not faster but much more compatible with the latest games.
Have fun, Felix
You need to download them from the viao-link site as the ones from the nvidia.com site are only for the desktop cards and not mobile ones.
Thanks for your help!
I`ve downloaded the new drivers from vaio and it works fine!
Thanxs!!!
Greetings
Chris 🙂
