I've searched through the forum for some threads about the FE21B.
I was reading one about the graphics drivers, and there was a link to the tweaksrus.com website.
Does anyone know which driver (from tweaksrus.com) i would need to tweak the graphics?
the graphics card is GeForce Go 7400.
thanks
there is a trick do use the forceware drivers (wich are highly advisable then the standard vaio ones)
extract the original drivers in a map (f.e. c:\nvidia)
download the lastest forceware, extract them in the nvidia map,he will replace many items and install, the installer will recognize the vidcard and he will install the lastest drivers.
thanks for that
it worked a treat!
