After a computer hang (???
) on my VAIO laptop and a reboot, I don't see anymore the wireless card in computer connections in Windows XP SP2. The wireless front button is on and the green led is lightning. Restarting the laptop don't change the situation.
What can I make ? Is the wireless centrino net card down ?
Thank you
J.-C. Stritt
Switzerland
Sounds like the card died?
Yes, i think !
JCS
not sure! I have had the problem and I have opened the memory cache (two screws) and the intel wireless card is on side. You remove it and replace it with care, and voilà! ..euh [:">] perhaps it's not possible on yours.. I have a VGN-S1HP .
