the most basic thing is your driver might be out of date, or your hotkey utility may need a update, i have 2 vaio's and have expirienced the same problem before, i updated the hotkey utility on my old laptop using the one i got this year and it worked fine. the problem can still presist if there is a cd or dvd in the drive, so before you connect the laptop to the tv remove any cd or disk until the connection is succesful, or you might want to try and do what "alfredbeaven" said.
Email if you need help on anything else on [email protected]
Cant promise anything!!
I have a laptop PCG FX 902P every time I connect it to my panasonic TV I can only get my
screensaver on the screen although I push the Fn+F8 key. I have connected to the TV by Red /WHITE/YELLOW lead to my TV supplied with laptop. Ihope someone out there can help me hoping??????. No data or photos appear.
ALF BEAVEN
Try connecting the computer to the TV before turning on the computer.
