I just got a brand new battery for my PCG-K315M and after running the battery down (as you should do with new ones) i plugged it in the mains to charge...the first time it worked fine and the battery was fully charged, so i took the pc out of the mains to let the battery drain for a second time...Now when i plug it back in to charge, the light flashes and it SAYS it is charging,but it stays on 0% and it ISN'T charging at all.
What should i do?
It might be worth taking battery out and checking all of the connectors , making sure they are all clean and look ok. Then replace battery and try again. It may just be the icon whihc is staying at 0%?
FWIW, if your battery is a lithium ion you do not need to discharge fully before recharging, this was only the case with Nicad cells that have memory.
Check the internal battery connections too & if they are ok open a case with Vaio Link.
Hi steppie,
If you have cleaned the battery & all connectors and there is still no joy make sure you call Vaio Link. I Believe there is a 90 day battery warranty for your laptop.
Hi steppie,
