having trouble actioning this. Does the desktop pick up the notebook or visa versa? Does the Desktop have the ability to network? It is the PCV RS502 and the Notebook is the PCG TR2. If you can help me I would be iternally grateful!!!
Pete
Actually none of the two is superior to the other - they are equal, even though the OS is different.
Please check VAIO-Link for an user-guide, as they have a pretty detailed one.
If you cannot find it, please reply again - then I will dig it out for you...
first things first....
how do you connect.... wireless or calbe???
how do you communicate.... router or direct???
are network cards installed properly
assign a common workgroup to simplify things
are you going over tcpip with or without netbios support
if you build it... he will come....
let us know an we will help
Joe
by the way... VAIO specialist... are you a forum rep??? cause only as an admin you can assign yourself a rank of VAIO-Master with only a 150 or so posts?????
OK
OK
OK
OK
that does it... i don't care what you say KEE... your working for sony...
no doubt about.... theres no other explanation for it... you know to much insider stuff................!!!!!!!!!!!!!!!!!!
joe
Hey if I did I would know a lot more about VAIOs other than the GRX series :smileygrin:
Oh and I would have an A series notebook.
YEAH...
the new A series is kicking.... nice notebook... specially the 17" version....
Joe
Yeah it does look like a good notebook
