Hi all,
I've recently insstalled Win 7 Prof and everything works except Network wireless. Looking in Device Manager, I can see there's an issue with Network Conroller but, neither I can update the driver nor reinslall it. Please share your knowledge if you know how to tackle this issue. Thank you all.
Hi Syd007.
You don't tell us exactly what you have tried which makes our job more difficult.
Is the physical WiFi switch on the front of the Vaio turned on?
What is the error code in Device Manager?
Which Intel wireless driver have you tried to install?
I presume you have reinstalled Windows 7 Pro 64-bit?
Have you tried installing the original pre-installed wireless driver here and followed the installation instructions carefully?: -
http://www.sony.co.uk/support/en/product/VPCS13L9E_B/downloads/Intel6200_WLAN_Driver_13.2.1.5_5481
Have you reinstalled all the drivers and utilities? In particular, have you reinstalled 'Vaio Smart Network' and turned on the wireless 2.4GHz on in the smart network utility?
You can find all the downloads on the Support website for your model here: -
http://www.sony.co.uk/support/en/product/VPCS13L9E_B/updates
Hi Syd007.
