Hi Guys,
As stated, I need the software for my LocationFree LF-B1 base station. In the long while since I last used it, I've lost the setup disc that came with it.
I can find US-region software for it but none for UK/EU. Any tips/ideas on where to source it?
Thanks
I have exactly the same issue except I have the original disk but it refuses to install on Win7 64-bit.
I find it rather annoying that the updated software exists, it just hasn't had the localisation done for Europe.
Nilo, if you have a note of your Serial Key then I could send you a copy of the install disk (LFA-PC2) since Sony still haven't responded to your message above.
Hi Guys!
I have same problem with EU region LF players (LF-B1) I've lost the serial key.
I have LFA-PC2 and LFA-PC20 original discs if you need i can send it to you..
If you have any solution the serial problem please drop a message.
I also have LF-B10 and LF-V30 US version LF players and works fine on Win 7 64 bit ,try LFA-PC20 (Vista copatible version) or download the upgrade file for LFA-PC2... here:
http://support.sony-europe.com/locationfree/up/download.aspx?site=odw_en_GB&f=LFA
