How can i creat a Folder to use it in the Vaio Pocket VGF-AP1?
Thanks for help
If you mean a folder to transport data, you can do it from the Windows Explorer just like any USB key or drive.
If you mean a folder for music, that is not possible the way you think it. Vaio Pocket index the music you put on them through IDv3 tags inside mp3s and Atrac pieces.
Typically, that's through Genre, Artist, Album and Title.
Could you be more specific ?
@HeartOfDarkness,
THX for your answer!
I mean a Folder for Pictures.
There is only one name "USER001" in my Vaio Pocket, when i create an new Folder in Windows Explorer i cant use it in the Vaio Pocket Menu. I want to separate my Pictures on my Vaio Pocket, so it´s more easy to find a special one! :smileythinking:
You need a folder in the root called "Vaio Photo" then in that you can put folders USER_001, USER_002, etc and put your pics in there.
