Hello.
I need the forceware drivers for my fs315h.
My notebook has a nvidia geforce go 6400.
Where can I find a place to download the forceware? On the nivida homepage is no download for go-cards.
Thanks for your help.
did you have to modify any ini etc.
Thanks. But don't you get any performance troubles if you use these modified forceware?
nope, I've had no problems with them what so ever. but define performance problems. As the Sony default drivers are old, those being much newer, they will naturally be better for performance etc.
I didn't need to modify the ini file, it went straight on.
Thanks for the info.
Do anyone have a url or something for the latest vaio forceware? I remember so far it was 77.70 or lower.
