`I have an old VGN-NR32m which as served me well i ve upgraded it to windows 10 and looking for compatible drivers, the main one is the ACPI\SNY5001 which is the firmware extension parser device , the driver is missing
Please help i ve tryed a couple but there not compatible for w10 i guess
Thanx in advance
Hi SUEBEAR69 and welcome!
Sony will not be supporting your Vaio for Windows 10 due to its age but I would expect most of the Windows 8 drivers to work OK.
The SFEP Driver and the SFEP Driver sustaining Patch for Windows Vista are on the Sony Support Website for your model and I think these will work for any 32-bit operating system.
https://www.sony.co.uk/electronics/support/laptop-pc-vgn-series/vgn-nr32m?downloads-num=35
Sony Firmware Extension Parser (SFEP) Driver
https://www.sony.co.uk/electronics/support/vgn-series-vgnnr300-series/vgn-nr32m/downloads/Z0003104
SFEP Sustaining Patch
If these do not work we will need to look for an updated SFEP Driver from another Vaio Model but most of these are for a 64-bit Microsoft Operating System. I presume you have installed Windows 10 32-bit?
Try the ones above first and if they do not work, or if you have 64-bit Windows 10, come back and we will try something else.
Hi Sue,
We're looking into this for you now, and we'll be back in touch with a response as soon as possible.
Thanks,
Owen
Hi i saved the file to my pc and did a computer searh install and i am glad tosay a driver was installed 8.0.2.4
thank you
