Need a drivers for Vaio PCG-2B1P, especially recent NVIDIA driver. Please help if you can! The Sony support section unfortunately does not recognise this model, so no drivers provided on support
Thanks.
Hi apyafg and welcome.
The reason you cannot find this model on the Sony website is because PCG-2B1P is not a valid model. It is possibly a chassis model but these can be shared by many models.
Look for another model number on the screen surround or above the keyboard. If you find a genuine model name we may be able to help.
If it is a desktop computer the correct model may start PCV- or VGC-
A bit of further research shows that the PCG-2B1M chassis is used for the model with the correct name of VGX-TP2S.
Look for a model name VGX-TPxx and you will be able to find downloads available on the Sony website.
Thank you very much, it really helped !
