Hi Saadi1986 and welcome.
Your Vaio model is supplied with Windows 7 Home Premium 64-bit. Have you installed a different 32-bit version of Windows?
If so, you will need to reinstall the 32-bit drivers from the download page for your Vaio here: -
http://www.sony.co.uk/support/en/product/VPCEB4J0E_WI/updates
You need to go into the 'Preinstalled Drivers and Utilities' Section and reinstall: -
Ethernet Driver (32-bit)
Intel WLAN Driver (32-bit)
VAIO Smart Network (32/64-bit)
If you have changed the OS, you may need to reinstall quite a few more!!
To activate WiFi follow instructions on Page 65 of your User Guide here: -
ftp://ftp.vaio-link.com/pub/manuals/Notebooks/VPCE/VPCE_H_EN.pdf
MY WIFI IS NOT WORKING IN MY SONY VPCEB4J0E, WINDOWS 7-32 BIT
Hi
I have the same problem - however i have tried to install both 32bit & 64bit drivers from sony website but no luck..
Please help.....
