hi there
it happened to me a few times, especially when I recover the laptopo from hibernation, that the computer's wireless doesn't work anymore and it's very annoying
when I check the wireless switch it's ON, but the led is turnt off...
so the only solution is always to restart and then it works...
does anyone have an explanation and a solution?
thanks
Federico
