perhaps someone has an idea here:
i do not know exaclty what to do, but it really sounds as if you caught a virus there!
I would try to recover the system - after all it's Summer, and your VAIO needs some cleaning as well ;o)
Hope that you can enjoy you VAIO's full performance soon again.
BR
CU
Have to agree with CU, a system restore will do it a world of good.
A system restore will do me no good if I can't get past the bios startup process...
Sometimes the system will run Windows fine for an hour, next it might lock halway through the boot process or even before it touches the hard-disk, e. g. when booting from a floppy, a cd or even during device enumeration and memory count.
The only virus I know that would cause low-level hardware problems would have damaged the bios, but that kind of problem wouldn't be so elusive, the box just wouldn't work anymore.
I fear it is a hardware problem, e. g. something caused by a voltage spike or a faulty component on the motherboard ....
