Hi
Sorry if I post twice ,because I can't read what I wrote and the reply.
If you have any solution in order to resolve my problem I'll be good for me.
My computer doesn't work well since I've erase some hiden files
One of them was the "net bios file" My network doesn't work.
When I try to repare the computer tells me " the TCP/IP is not activate It's not avaible to continue"
I don't know how to make my computer good as the first time.
If you have a PCV-RX 1 or a VAIO maybe if you copy this file it will work for me.
Iwanted to format my hard drive ,but windows is on the restore CD and it may not work.
Thank you by advance for reply
Hey CJ
Been looking into this and found this support document which you might find useful.
The best thing to do is rebuild your network connections.
HTH
Hi Kee-Lo
How are you ? Fine
Thank you for reply .
I'll try to rebuild my network thanks to your link
Thank you very much
Musicaly yours...
Cutee
Hey,
Yeah I'm good thanks for asking. How about you?
Hope it goes well.
Yeah I'm quiet good (better than my computer
I allways have the music in my mind
There will have a new group of French Rn'B who will be famous ,but I don't ask nothing for the moment because their album is not yet on the shop . I will tell you
See you soon
Cutee
There will have a new group of French Rn'B who will be famous ,but I don't ask nothing for the moment because their album is not yet on the shop . I will tell you![]()
Ok no problem Kee you will be inform at time
Hi Kee-Lo
Their first single is "Laisse toi du temps" with Kader (the 2°singer of willy Demsey)
If you can listen to Ado Fm radio on line or by waves
musicaly yours....
Cutee
Hi Kee-Lo
I resolved my problem. :smileygrin:
I installed windows xp home (a friend lend me the cd of instalation) All files are good now.
Sony should give a CD rom instalation of windows when we buy a computer not only the restaure CD .
If I had it, my problem would not be a problem
See Ya
Thats great Cutee!
So how's life? BTW I still haven't heard that song you mentioned...
