since I renewed my notebook, my mouse doesn't work?
Are you referring to the touchpad or an external mouse?
If the touchpad then in Device Manager, under mice and other pointing devices right click the standard PS/2 mouse and select uninstall, then scan for hardware changes.
This should re-install the correct drivers and the device will then be listed as a PS/2 port pointing device.
