My laptos has big problem
gianlucala
Visitor
Can anyone help me?
After 3/4 hours of work my laptop swith off itself automatically without any reasons. After that with the power button the laptop start again without appantly problems......and than start the hystory again.
5 REPLIES 5
gianlucala
Visitor
Thanx felly...but I check my pc with the latest version of Norton.....than I don't think so......
felly
Visitor
Can anyone help me?
Hi maybe it's a virus
check that site
it seems to be sasser ...
http://www.secuser.com/alertes/2004/sasser.htm
profile.country.en_GB.title
kee-lo_
Member
Is the laptops bottom hot?
profile.country.GB.title
rich912
Contributor
Check your CPU temperature with MobileMeter.
Go n-éirí an bóthar leat
goliath0011
Visitor
might be a problem of over heating.
the laptop will switch itself off if the CPU has reached critical heat level. you need to check your fan.
do u have a diagnostic CD?
