yeah um title sez it all
Its a desktop. any problems beforehand?
yeah its a desktop one of the ones with monitor n keyboard attcahed to main computer.
basicaly i switch it on n it starts with the light red instead of green and the fan goin mental, its happened before n i could get it started by repeatedly switching it on and off but now that doesnt even work. got it started last nite and have cleared it of viruses, ad/spyware etc then shut it down and have been trying to start it up again all day.
Sorry if I sound condescending but how attached?
Is the computer integrated into the back of the monitor? or are the keyboard and monitor just connected by wires?
Do you know which model of Vaio you have?
If it is an ordinary desktop/Tower I would suggest you gain access to the computer's innards and clean all fans and vents that you can see.
Then try again.
Sounds like a diagnosis from your friendly neighbourhood Computer shop is needed I am afraid.
Unless of course its still under warranty.
its like literaly attached
cant really get inside of computer as its not a standard tower kinda thing
cheers for ur help managed to get it started, dunno wat was goin on, think it may ave been 2 hot as there is a radiator opposite side of the wall to it, woops, atleast i hope its that and it doesnt happen again
Hi liveinadive,
Welcome to Club Vaio,
like William said it's worth checking that the air vents you can get access to are clear.
