Hello,
I am wondering about something that I have noticed with my battery. When I boot up my vaio and the desktop loads my battery (which is fully charged) is at 90%.
I am wondering if this is normal or is there a problem with my battery? Any help would be appreciated. Thanks
~JamieM
Hi JamieM,
This has been mentioned several times before, I would think the drain on your battery is due to power used in starting up your Laptop and nothing to be worried about..
Sorry, and thank you for your quick reply.
There's no need to apologise, that was not my intention..
I was only try to make you aware that the battery power loss was a common occurrence..
