Ok just got the Vaio today and I'm having issues with the multitouch, web pages keep zooming in and out when im just using a single finger and using two fingers doing the pinch zoom is difficult. Does anyone else have a problem like this or am I doing something wrong?
same problem here on my VPCEB1E1R.
i think its because of cheap touchpad hardware and crap driver software. the proper working multitouch got Apple only i guess.
so i just turned off this feature on my laptop.
p.s. Install mac osx on ur vaio and have a nice day.
Yea I turned it off aswell was getting on my nerves, it just keeps doing things when I don't want it to, zooms in/out when i just touch it.
Yes I think the trackpad is either faulty and needs an update or is cheaply made. Sometimes its a struggle to move the cursor around. Please is there some fix for this, thats why the mutlitouch was not operating properly.
Similar problems here on a VPCEB4X5E . If multitouch is enabled, the mouse pointer stops moving as soon as the software drivers are loaded. You can tell because the mouse works correctly for those ~2 seconds just after logging in Windows.
