hi got .FS -VGN- FS115M ...DVD DW D56A .I have my laptop for 4 months and it worked fine at the start......over the last couple months it been having problems like playing some dvd movies but now it wont play any dvd moives .it just doesnt see my dvd in the drive it start up but nothing happens ..i watch them before on it and even new one wont play install new dvd software..play a couple of time ,LAST MONTH now wont play at all....it reads dvd data and cd and burns ok but wont play any moives now .......uninstall all my programs i photoshop ect........still didnt work did a complete system restore ....update all the drivers ...stilll dam wont work...would clean the head make any diffrents..cant see that wotking as it see dvd data disc/////// i heard there alot of problems with the dw d56a...so if i sen it back will they put the same model back in........or should i just buy a laptop dvd player and put it in my self
just give up smoking thinking about starting again ...thanks sony.....should i just send it back
Assuming that you have tried the firmware update for the drive and this had no effect then yes, contact support for a repair.
I understand, from a previous post, that Sony is fitting the DW-D56A Rev2 drive as a replacement. I hope that it is more reliable than its predecessor!
thanks as i just looked at other drive out there .and the cost between 200 300.....i email tech hope to hear from them soon
As an old moaner about a disfunctional DW-D56A in my 4 month old Vaio VGN-A417M (along with many, many other users complaining of the same!) I solved my problem by chucking the Sony/Lite-on crap unit out and replacing it with the new NEC-6650A which performs great and has given me no problems at all and no need for firmware tweaks.
Now if someone could just tell Sony to make dismantling of their damn notebooks a bit easier it would help anyone wanting to take this route!! Apart from a load of different length screws at the back of the case they cunningly hid two under the keyboard which took by laptop repair shop a while to find before they could split the case and install the drive, Guess Sony doesn't want your average complaining user to fix their problems - LOL!!
have fun
Man I wouldnt fancy taking apart my A217M for anything....
Well for anybody out there having problems with the DW-D56A in their Vaio, I had the same problem a month or two ago and Sony Support replaced the drive with a "v2" D56A (which leads me to believe its a fixed version of the drive). Since then, absolutely no problems with the drive; records and reads DVD fine. None of those dodgy "stalling" noises that I used to get near the end of a DVD.
So, if you do have problems with your current DVD drive, then a replacement from Sony Support should be a good solution. Still, would be interested in doing an upgrade myself in a year or so to a better performance drive (if a walkthrough or something was available, of course. Wouldn't try it on my own).
Slan lads
Dave
Dave
Nice to see you got it sorted, but Sony really need to get better support for people internationally
a
well now over a week and sony still havnt even replyed to my case number ........does any one know what the tech support phone number is for the uk thanks
0870 240 2408
