My mouse/touchpad has stopped working. An external mouse works fine, any ideas on how to resolve. thanks
Hi mercurysony,
Go to
Device manager and expand the
Mice and other pointing devices.
Does it list a pointing device, if not and a PS2 mouse is listed try the following.
For XP.
Right click once on
PS2 mouse and select
properties.
Select the
'Driver' tab and click on
Update driver.
A new Hardware Update Window will appear, select
Install from a list or specific location (advanced) and click
nextThe window now changes select
'Don't search I will choose the driver to install' and click
next.
If 'Alps Pointing-device' (possibly Alps Pointing-device for Vaio) appears in the new window, select it and click next.. (if the 'Alps Pointing-device' does not appear in the list remove the tick from 'Show Compatible Hardware' and select Alps Electric from the Manufacturer column then 'Alps Pointing-device' (possibly Alps Pointing-device for Vaio) from the model column and then click next.
Wait for the driver to install then click Finish, a System Settings Change window should now appear prompting you to restart your Computer and click
Yes to restart.....
