hi , can any one help. I have had to reinstall windows on a vgns3xp, having done so i cannot operate many of the original utilities, the most annoying being the facility to modify the mouse functions on the keyboard
how do i enable these functions
thanks
Hi lost in tech and welcome to Club Vaio.
You need to download the Prenstalled Utilities for your model from VAIO-LINK - installing these in order should get your utilities back. Alternatively, if you have C:\Utils\Utils.exe try running that.
If you just want to fix your touchpad, download the Alps drivers and touchpad utility from HERE
Hi, thanks for the link, however i tried it with no luck, it will not install as it comes up with " this application is not compatible"
Any other ideas
I have downloaded all the utilities nd installed them in order . In device manager i have problems with ethernet controller, mass storage controller, pci device and ugx aswell as usb controller
thanks
Make sure that, after installing the utilities, you re-start your computer prior to installing the drivers.
