i have vgn-tz3rxn notebook. after windows7 is downloaded, motion eye web cam doesn't work! can anyone help me many thanks in advance.
I've done the same with a VGN-NS10/E and I'm also interested in an answer. My guess is that the webcam will only work with the Sony provided software that the clean install has removed. So either a restore to factory setting or do without
Hi leoeagle07,
Sony do not support Windows 7 on your model but you could try installing the Vista camera driver that came pre-installed - assuming that you have opted for the 32bit Win 7 OS.
Have a look here:
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGN-TZ3RXN_B
Message was edited by: rich912
