When I reinstall my Media Center by Xp Pro, and I have all the drivers perfectly installed (with sound) I can use the motion eye without any problem
the problem is that when I have used it, the sleep mode, standy and even shutdown doensn't work anymore, it hangs!
if I don't use it, I can do whatever I want
anyone who has the same problem?
thank you
Hi sweetCoffee,
As I already posted in another thread, I have exact the same problem. (only difference is I have the FE-11S, modem/sound/functionkey -problems already solved, now only that damn camera)
I have mailed Sony, tried the E-support. No luck yet, planning to fax on monday. Do not think this will get a result.
May I ask you if you have found a solution to please let me know.
I will look further an will post a solution if I have found one.
Thanx in advance,
manu greetz,
Lester.
