is SONY VGC-JS LAPTOP MOTHERBOARD MBX-197 A1716835A A-1716-835-A 1P-0087J00-6011 US, be used to replace MB11 IP-008BJ00-6011 MBX-197
Hi there,
Welcome to our boards. We will look into this for you and get back to you.
Best wishes,
M
Hi again,
You can contact VAIO Support via the following link: http://bit.ly/2zVrDnV. They should be able to advise you on whether the motherboard you mention is the correct replacement.
Thanks,
Owen
