I own a VGN-S1XP and have already installed a Hitachi 7.2k RPM 8MB 60GB hdd and the "maximum suggested" ammount of ram (1 GB) but since I work mainly in the field of 3D Animation and SFX Photoshop etc. I need as much ram as possible. I have found over the internet a 1GB module (DDR 333 SO-DIMM 300$) and I am thinking of buyng two but I am affraid it won't work. Any of you have tried that with your VAIOs?
By the way, if you are willing to sew a bit off your vaio casing you can fit in there a Lacie DVD-+RW Dual Layer (talking about the external slim version) It works for me 🙂
Oh, and why is it that when I right-click My Computer and select Properties I get something around 600Mhz instead of 1.7Ghz? My settings are set to Performance... Go figure.
Thank you all, any assistance is welcome.
True in all accounts. will post back when I have made the mods.
