I have recently had a 100gb HDD installed in my Sony Vaio and i'm considering putting more memory in next, is this a DIY job or is it best left to the experts?
thanks in advance
eamonnschevy
you mean memory as in RAM?
No this is an easy job, first go to www.crucial.co.uk to buy some RAM.
Their RAM is cheap and best quality and you can find the exact RAM you need for your VAIO.
Then go here http://www.vaio-link.com/tutorials/memory/memory.asp?l=en
the above link will then show you how to install memory modules
Hope that helps,
Ali
yea it was Ram i meant,
www.crucial.co.uk here i come
thanks for the quick helpful reply
all the best
eamonn
np. glad to help
