Hello, I'm searching for a little help
I have a nice Sony Vaio VGN-CS11Z/R laptop. It originally came with Vista OS, but recently I reinstalled it to Win 7. Because of that there seems to be a problem to locate a suitable driver to one of the devices. I've tried searching, but kinda failed ^^ Somehow the Sony support webpages for computers with Win 7 didn't even open to me.
Here are the hardware Ids:
PCI\VEN_1180&DEV_0592&SUBSYS_903F104D&REV_12
PCI\VEN_1180&DEV_0592&CC_088000
Anyone got any helpful suggestions for me, please?
_________________________________________________
Nevermind, finally found it. Sorry for the post ^^
Message was edited by: ireklima
i have the same pc but i have olny drviers for Vista.
I see you found all the drivers for win 7.
Are they for 32 or 64 Win 7 ?
Can you be so kind to send me the ones you found ?
For example posting them on a server so i can download them ?
I would be very grateful to you ...
Thank you.
Luigi
Hi Vedlig,
That is the Ricoh Memory Card Slot and requires the 3 Ricoh Memory Card Reader Writer Drivers for MemoryStick and SD cards.
These are not available for Windows 7, so I would try installing the 3 Vista drivers from the original drivers download page for your model here: -
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGN-CS11Z_R
They should install OK on Windows 7 but if you have any problems, come back.
As listed above, try the 3 Vista Memory Card Drivers as therre are no Win7 drivers:-
https://www.sony.co.uk/electronics/support/vgn-series-vgncs100-series/vgn-cs11z/downloads/Z0003020
https://www.sony.co.uk/electronics/support/vgn-series-vgncs100-series/vgn-cs11z/downloads/Z0003021
https://www.sony.co.uk/electronics/support/vgn-series-vgncs100-series/vgn-cs11z/downloads/Z0003022
