Please, my C: icon is missed!!!!!
Solutions ? Thank you very much.
a bit more information would be helpful. tell us the full problem your having
Thank you for reply.
Yes my C: volume icon in Risorse del Computer is missed. There is not !!!!!
Please, sir any solution.
Scuse me for my english language. Hi
Hi nunziovaio,
I am not sure that I understand your problem. Are you having trouble with the volume control, either via Ctrl + Fn key, or (on some models) the volume control buttons.
If you can detail the problem a little further and also let us know your model number it will help us to provide assistance.
Hi nunziovaio,
Post your question in Italian if it helps
