VGC LT1m
recently purchased this desktop but seem to be haveing problems getting the mic to respond correctly,playback and Skype sound like I am in a wind tunnel,is this just normal or can I set up quality and sensitivity manually?Good Evening!ps should moving eye webcam follow movement?
Same problem with a VGC LM1E
Any solutions??
I am currently having that problem with an LT1M too.
I have tried to adjust the microphone boost in control panel - sound - recording - properties - levels but without much luck.
I will keep trying to find a solution and report back
I have the same problem with my LA3 all in one pc when using skype, the person on the other end cant make out what I am saying at all despite me pratically shouting on my end :smileyblush: , however when using the video call feature in msn messenger its fine.
Hi everyone
Can you let us know which versions of messenger / skype etc you are using?
Vaio-Link are currently investigating the mics
