Hi, can anyone confirm if a microdrive (typeII) card (specifically a IBM 4Gb one) will work in the buit in card reader on a Sony RS402 desktop.
Thanks
It should work no problem, as most digital cameras that use the compact flash cards can also use the microdrive.
