I have formatted a Micro SD in my dash cam and my Macbook pro wont recognise it.
When i bought it i put it in the laptop and it was ok until i formatted it.
Help needed please
rich
Hello @richrkg,
which card are you talking about?
Where did you bought it?
Did you try to re-format it?
- Nic
Hi
1/ SanDisk micro SD
2/Currys
3/First of all i put the SD into the computer,it showed up in the right hand corner or the screen.
Then i put the SD into my dash cam it told me to format it.
Then i did a little recording and put it back in my computer and it didnt register on the computer and it wasnt visable in Finder.
Richard
Hello @richrkg,
may I ask, why you are asking on the Sony Community about a SanDisk-Card you tried to format in a Apple MacBook and put into a non-Sony dashcam?
I would say that contacting the SanDisk or Apple support would be a more viable option to receive support for your issue.
- Nic
Hi!
Reformat it.
Do not use APFS "Apple File System" or FAT32.
Try ExFAT or FAT -filesystem, it is option while formatting.
ref: File system formats available in Disk Utility / Mac
