Hi i have some proble with memory upgreid.
I wana upgredi my Vaio to 8G Ram but when i add new sodim (4G), Bios and Windows 7 64bit see only 4G not 8G i try only new one sodim remove original all is okey no error or other problems but i need 8G not 4G
Its there any bios upgreid or some other solution becose on specification for this laptop is writen Max 8G.????
It should accept 8GB according to the specifications.
What memory did you buy and did the manufacturer guarantee compatibility?
